PCB manufacture - Drill File wrong?
Discussion in 'General Electronics Chat' started by JBmtk, Jul 19, 2010.
  1. JBmtk
    Jun 29, 2009
    25
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The batchpcb image is too small to see hole placement - the holes in the pdf from 4pcb has no component and trace reference to compare with. How did you produce the Gerber files?
  3. JBmtk
    Jun 29, 2009
    25
  4. sage.radachowsky
    Member
    May 11, 2010
    241
    38
    I used BatchPcb and got fine results lately. It's a good idea by SparkFun people. I hope it keeps going.
    Check the FAQ on drill files:
    Check here
    And check here.
    Both mention drill files -- one is about scale or something, and the other is about the origin.
    There is also something about format of the drill file -- whether something precedes or follows somethiing else -- worth spending some time reading.
    Mine worked fine, and showed up fine in the preview. I made mine with KiCad.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
