is there any kinda of machine to make pcb. I m looking for such pcb making machine which can be use at home in cheap.
12,Having a friend that is in printing, he makes photo positives for me and I use photosensitive circuit boards by exposing them to sunlight. Whether that is cheap? You decide.
I think if "cheap" is your main criterion, you will struggle to beat the commercial services that will make one for you. I understand you might value your time at zero, but when you add up the cost of all the supplies and equipment, cleaning supplies and so forth, you are likely to spend more doing it yourself. If you make multiple boards and actually consume all of your supplies efficiently, your cost may come down but so would that of the commercial service.
I will disagree. The process is both cheap and easy once you get it down (my cost is around $2 / copy not counting the board stock) and beats breadboarding in time by a huge amount. It is completely repeatable by other people, removes a lot of potential errors on established designs, and you can build one if that is all you need. Too each his own.Making your own PCB's is a good hobby exercise, but is not worth the trouble.
Boards are typically primitive and poor quality.
Not cost effective.
Process is toxic, messy, time consuming.
A service provider is by far the cheapest way to go, and you get a reliable, professional product in the end.
by Jeff Child
by Jake Hertz
by Duane Benson
