pcb layout with custom part?
Discussion in 'General Electronics Chat' started by krnx2oh7, Sep 28, 2012.
  1. krnx2oh7
    Jul 17, 2011
    20
    I want to make a pcb file to send to a board house and the layout is very simple. Can I just draw the pads and not place the components at all?
    I say this because the components aren't in the library and I would have to make a custom part.
    Can I just place the pads manually and route it myself. Or do I have to make the custom part to place in the footprint.
    I'm using pcb artist.
  2. t06afre
    May 11, 2009
    5,939
    1,222
    All PCB tools have an option to create and add custom footprints. And creating such is part of the usual trot for every PCB designer. What PCB tool do you use? and can you post some info about the footprint. Even if I do not use your design tool. I might be able to come up with some tips
  3. mcgyvr
    Oct 15, 2009
    4,795
    979
    yes you can place the pads and traces manually without creating a component in the library.. The board will be EXACTLY the same as if you created the library part. Well assuming you place the pads correct manually :)
  4. kubeek
    Sep 20, 2005
    4,691
    806
    But then, if you ever plan to use that part again it will be better to create the part in library.
  5. mcgyvr
    Oct 15, 2009
    4,795
    979
    obviously..
  6. t06afre
    May 11, 2009
    5,939
    1,222
    I have a rule that the only place any PCB part may be added. Is in the schematic. Even for the hobbyist this make the design more easy to audit
  7. mcgyvr
    Oct 15, 2009
    4,795
    979
    yep.. I agree
    but again there is no difference in what you will actually get on the fabricated PCB so what he wants to do is totally fine.. Just the lazy way :)
  8. krnx2oh7
    Jul 17, 2011
    20
    thanks for the responses.
    I have one more quick pcb related question.
    If I am doing a through hole. What layer do I put the pads and routing
    top copper, top solder mask, or bottom copper, bottom solder mask.
  9. tracecom
    Apr 16, 2010
    3,880
    1,396
    You put pads and tracks on the top copper and/or bottom copper.
  10. mcgyvr
    Oct 15, 2009
    4,795
    979
    your program "should" be smart enough to automatically do the mask layers based on the pads.
  11. t06afre
    May 11, 2009
    5,939
    1,222
    It looks like yo are quite new to this. Feel free to post your schematic and PCB for comments. We will not bite your head off in any way. But it could save you some time and money
  12. nigelwright7557
    May 10, 2008
    488
    71
    Its much better to do a schematic then convert that to a pcb ratsnest.
    This is becasue a schematic is much easier to read.
    Also if you make any changes you can forward annotate from the schematic any changes and then you will know the shcematic and pcb match.
  13. t06afre
    May 11, 2009
    5,939
    1,222
    Ah that brings me back to to days of DOS ,IBM PC, and the Smartwork software from Wintek
  14. kubeek
    Sep 20, 2005
    4,691
    806
    A schematic is also much less prone to errors than drawing the pcb straight away.
