PCB Layout Questions
Discussion in 'General Electronics Chat' started by tracecom, Jun 2, 2010.
  1. tracecom
    Thread Starter AAC Fanatic!
    Apr 16, 2010
    3,879
    1,396
    I am using ExpressPCB to lay out the first PCB I have done in many years, and even though it is a simple board, I have some questions.
    1. ExpressPCB recommends .150" wide tracks for up to 6 amps. If I put identical .080" wide tracks on both the top and bottom layers, will that be as good?
    2. What about power and ground traces; I know they should emanate from a central rail, but is it good practice to "loop" the tracks or to maintain a "star" configuration.
    Any other advice is appreciated.
  2. t06afre
    May 11, 2009
    5,939
    1,222
    If this is a prototype, and not something that goes into production. You can solder a non isolated coper wire to the track, or just melt solder metal ontop of the track.
  3. tracecom
    Apr 16, 2010
    3,879
    1,396
    The board I am laying out is not for production, but will (I hope) be used for field trial. Because of this, I would like to avoid adding wire/solder. Thanks for the suggestion.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Two parallel wires will work.
  5. eng1ne
    Member
    Dec 4, 2009
    97
    Your grounding requirements depend entirely on the circuit. A good rule is to separate analog and digital grounds; both should terminate at one point as you state.
  6. retched
    Dec 5, 2009
    5,201
    313
    The grounds should terminate as close to the external power source connector as you can get it.
    Actually there are a few hundred ways of accomplishing these tasks. It depends on how fast the signals you are using, and, how noisy the environment is.
    Heat dissipation should also be considered while running traces. A copper fill can be used as an effective heat sink in many applications.
  7. mcgyvr
    Oct 15, 2009
    4,793
    976
    you need to state your pcb copper thickness (1/2 oz, 1 oz, 2 oz,etc...) before we can tell you if the trace is sufficient for 6 Amps. Also your acceptable temp rise over ambient. Don't forget any heat input from components attached to that trace.
    http://www.desmith.net/NMdS/Electronics/TraceWidth.html
  8. cmancuso
    Jun 7, 2010
    For the ground plane, if you are getting the more expensive boards for Express PCB you could use a solid ground plane on the bottom layer of the board, and making sure you have no islands on the ground plane.
