PCB layout for TDA7560
Discussion in 'The Projects Forum' started by syber, Dec 17, 2006.
  1. syber
    Nov 8, 2006
    Hi all,
    I'm planning to make a audio amplifier with TDA 7560. But currently i can't find any pcb layout for the same. If any one can provide me the layout it would be easy for me to develope my project.
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    On one level, thingmaker3 has given you a good solution.
    However, given the incomplete nature of the illo you posted up, I suspect you may need the actual component dimensions. Eagle Light will have libraries of parts that might catch the passive components, but you'll need the data sheet from the manufacturer (TI?) for the package outline.
  4. Johann
    Nov 27, 2006
    190
    30
    I agree with beenthere and also, looking at the attached image, you'll see that the "circuit" still needs all the peripherals such as pre-amps etc. You'll need a complete diagram with package dimensions before starting with the pcb design.
