PCB Layout for Package Variants
Discussion in 'The Projects Forum' started by moneymcr, Feb 21, 2014.
  1. moneymcr
    Mar 8, 2013
    I'm designing a PCB where I'm using a TE 40 pin FPC connector. Just in case this part becomes hard to find and buy, I want to design the PCB to accept an alternate part. However, finding a part that exactly fits the land pattern has been challenging. I have found several others that are close, but all of them have slightly different hold downs requiring slightly different land patterns.
    I'm sure this isn't a new question by any stretch, but how could I design the pattern to accommodate either part? Is it possible to simple make one pattern that is oversized to fit two slightly different connectors? Does this present a problem during assembly? Are multiple soldermask screens necessary?
  2. tracecom
    Apr 16, 2010
    3,879
    1,396
    It is possible to combine two different part footprints into one. I have done it with a combination of a coaxial power input jack and a two connection terminal block. I created one of the part footprints and then the other; then, I created a third footprint that included both parts. The silk screen shows the outline of both parts, but only one is installed on the PCB.
    The degree of difficulty in doing this, of course, depends on the two parts involved.
    moneymcr likes this.
  3. ErnieM
    Apr 24, 2011
    7,440
    1,627
    If I was unsure of the future availability of a particular part I would try not to use it in the first place.
    Multiple solder paste screens are probably a good idea.
  4. moneymcr
    Mar 8, 2013
    Thanks for the reply.
    The reason for the two sources is simply to make sure I have options down the road. If one ends up having a long leadtime, I'd like to swap it for the other.
