PCB ground copper area
Discussion in 'The Projects Forum' started by araba1980, May 3, 2013.
  1. araba1980
    May 25, 2011
    Hello
    I have a question about PCBs. Why is the ground copper area large, not only line? Like this picture;
    Is there any advantages of it?
    I think, this is related with magnetic or electical field, But I dont know detail,
    please help..
    Thanks.
  2. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    It's called "ground fill". It allows for easier ground connections, and can also be cheaper to produce. In the routing process it makes it easier to connect pads because there won't have to be ground traces all over the place--just a solid plane on the board. There are quite a few advantages to it.
    Matt
    araba1980 and #12 like this.
  3. #12
    Nov 30, 2010
    16,704
    7,351
    The ground plane also suppresses radiated energy a little bit, if there is a copper plane on the other side of the board it creates a bit of capacitance to smooth the power supply, and it takes less chemicals to not etch away all that copper that isn't hurting anything.
    There are probably more advantages that we haven't thought of yet.
    araba1980 and DerStrom8 like this.
  4. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Oh yeah, and having a low-resistance ground plane could be absolutely critical on some high-precision boards.
  5. Brownout
    Jan 10, 2012
    2,375
    998
    Think about this: the current from every component on the board has to go through the ground wire. If you have too much resistance, all those currents cause the gound voltage to bouce up and down. When that happens, every component that depends on ground for 0V reference is instead getting a voltage that is jumping, and thus isn't operating as they should.
    araba1980 likes this.
