PCB Fabrication
Discussion in 'General Electronics Chat' started by Skeebopstop, May 18, 2009.
  1. Skeebopstop
    Thread Starter Active Member
    Jan 9, 2009
    358
    Hi All,
    I recently had our production manager come back to me and ask that I alter a 4 layer PCB design to the 'cheap way' in the attachment, versus the 'expensive way' I used.
    Can anyone comment on this? Are there any repercussions of me allowing him to alter the process?
    Regards
      File size:
      64.6 KB
      45
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    How high frequencies is this board? The only pitfall I see is dielectric constants of the board, and that would only affect really high frequencies. I have to say I'm no expert in this though, just my 2¢.
    Oh, then there is voltage breakdown, which is less common as an issue.
  3. Skeebopstop
    Jan 9, 2009
    358
    I did find an e-book which discussed this briefly. Although prepreg is the same material, I guess the tracks are more prone to 'sink in' a bit during fabrication and as such the thickness can be slightly less than intended.
    This would impact the dielectric and clearances slightly, but as far as I can tell this cannot be predicted to such a degree and must be assumed to be the same as the core.
    I don't see any reason why this assumption is not valid, considering the material is the same, only the process of application differes.
  4. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    I have always used the standard method of board production. We made processor boards with clocks of 30 and 40 MHz. Our analog sectioins routinely went up to about 1 MHz.
    Even the other division of the company, working on RF circuits, used the standard method of board production.
    Unless you have a specific reason, that is somewhat measurable and reproducible, I would always start with the standard method. The standard method is pretty flexible with layer thicknesses and such.
    There's 2 more cents.
  5. Skeebopstop
    Jan 9, 2009
    358
    Sounds good to me. Thanks.
