Ok, so the directions for the toner transfer method say's I need semigloss paper. Is their something I can substitute that with. Since I don't know of any local store that sells this and the stuff I saw was like $50 or more.
Not willing to pay that just want a few slice of paper so I can do the transfer. Is their any other transfer agent I can print on with my computer.
Not willing to send away or buy online.
Thanks for any help
I read on one post that you can use tape to draw the lines since the acid doesn't eat away or under the electric tape.
And somebody said you can use permanent markers or sharps? ( don't know how the acid won't eat away this but if it works I would be up for it)
And somebody said their is a special etching pencil that you can send away for use to be sold in radioshack. (<-not willing to send away for anything though so this isn't any option )
Curious what is the best quality and way of doing it between the 2 above methods.
Also curious to know if their is another method of doing it? Other then the fact of using a 3 party company to make the board for you and charge you in the process.
Note this is going to be my first time etching a board and I don't want to spend alot of money on stuff until I have had a few practice runs at it. And they are successful!
The tools I have are the ferri...etc acid , drill to drill the holes , electric tape , sharps pens ,plastic pan to pour the acid into (one of those plastic painters trays)...etc , soapy water , and the correct printer to do the toner transfer with (though I don't have the semigloss paper for the transfer substitutes?) , also any iron and the copper clad board.
Other then that I have nothing but the components to solder onto the board if all goes well with the etching.
Hopefully I don't need to spend anything more?
Note if I cann't use the printer/toner method because I cann't use something other then semigloss paper then I would be up for manual using a sharpe or tape to make the lines ...etc
I would just need somebody to talk me threw the steps ...Is it just making the design with the tape or sharpe then stick it in the acid. If so then how long to stick it in their?
Thanks for any help
