PCB Etching - Toner Transfer Method
Discussion in 'General Electronics Chat' started by nDever, Dec 26, 2014.
  1. nDever
    Thread Starter Active Member
    Jan 13, 2011
    154
    Hey guys,
    In most variants of the toner transfer method, single-sided glossy paper acts as the medium onto which the toner is printed. However, in some versions, I've seen magazine paper used as well.
    It would seem like all of the ink from paper would get transferred to the board, and not just the design.
    Has anyone here successfully used the magazine paper method? Does it work well?
  2. bighand
    Member
    Apr 2, 2009
    18
    8
    Magazines are printed using a different kind of ink that doesn't come off when heated. I use magazine paper for etching and I've never had any problem with the ink coming off the pages.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    I have, the ink only sticks to the toner. When heated the toner becomes sticky in other words.
    I use wax paper nowadays, it is easier to store and works as well.
    How I make PCBs
  4. nerdegutta
    Dec 15, 2009
    2,565
    805
    I use Ferric Chloride. :p
    I've tried magazine a couple of times, with various success. My best toner transfer results have been with glossy photopaper from staples, printed win an HP laserjet P 1102.
    sirch2 likes this.
  5. nDever
    Jan 13, 2011
    154
    Sorry to bring this back from the dead, but specifically what kind of glossy paper works for you guys? I'm guessing inkjet paper wouldn't work?
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    A thread belongs to the OP (original poster). Trying to take over someone elses thread is called hijacking, which is not allowed at All About Circuits. I have therefore given you a thread of your very own.
    The thread in question is quite recent.
    This was split from
    To answer your question, magazine glossy print is very thick, and has clay in it as part of the mix. When feed through a laminator the print binds to the plastic toner, which has a tighter hold than the print to the paper. You will not I say print, not ink. It is a layer that can be removed.
    I have done this technique and it works. But unless it is a womans magazine from a doctors/dentists office I have trouble destroying anything in print. A personal affectation.
    The glossier and thicker the paper out of the magazine the better.
  7. strantor
    Oct 3, 2010
    4,302
    1,989
    Pages out of magazines worked best for me, better than all the types of glosy paper that I tried. Much easier to remove. Easier for heat to penetrate the super thin sheet.
  8. nDever
    Jan 13, 2011
    154
    I don't understand. I was the OP of that thread.
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    My bad, I'm tired. What has been done has been undone, with an explanation besides.
  10. GopherT
    Nov 23, 2012
    6,304
    4,027
    That's what all of the hijackers say!:D
