Do you use carbide or high speed steel?The thin drillbits are more expensive and break more often. I just use 0.8mm drillbit for everything, unless something has real fat legs then switch to 1.0mm. And buy 0.8mm and 1.0mm bits in bulk packs like 10 or 20 at a time to get costs down.
That also saves time in switching drillbits around and checking which holes are which size, so it is less work there too.
Are you kidding? Sharpen a .031 inch drill bit? You must have much better eyes than I have!If you like you can sharpen then on any bench grinder too.
You don't need "eyes" as such, just hold the drill bit at roughly the right angles and touch it to the grinder, as with all drillbits.Are you kidding? Sharpen a .031 inch drill bit? You must have much better eyes than I have!
by Jake Hertz
by Duane Benson
by Jake Hertz
