PCB design
Discussion in 'General Electronics Chat' started by nathomas, Apr 8, 2011.
  1. nathomas
    Mar 3, 2011
    82
    I have a circuit that uses +15V, -15 volts and ground. My ac/dc converter churns out +Vo and ground at 15V. Does this mean that I can use these as +15V and -15V resp and the body of the equipment as the ground? I know I can just test the ac/dc converter to see what output I get, but I thought I can verify beforehand. Plus if the ac/dc converter gives me only a +15V and ground, is there a way I could produce a -15V?
    Thanks.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    DC to DC converters are pretty off the shelf. One black box should be able to handle your job.
  3. nathomas
    Mar 3, 2011
    82
    thanks..i tried it and the ac dc converter gives out +15 and -15V..so no trouble...
  4. nathomas
    Mar 3, 2011
    82
    actually the ac/dc converter that i received does not have a dual output and a dual output converter is pretty expensive. a dc/dc converter is expensive too. any solutions?
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    It would help a great deal if you would tell us what your circuits' current requirements are, and what input power you have available.
  6. nathomas
    Mar 3, 2011
    82
  7. nathomas
    Mar 3, 2011
    82
    My input is an ac 110V. And i have to power the circuit shown above
  8. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    nathomas likes this.
