PCB Design PIC18f4550
Discussion in 'Embedded Systems and Microcontrollers' started by 74266, Aug 22, 2016.
  1. 74266
    Mar 20, 2016
    41
    I plan to make a PCB design by basing it in this picture but my classmate said that there should be a capacitor connected in each leg of oscillator and there should be a resistor in pin 2 that is connected in vss and since port B will be mostly used I should put each resistor in each pin of port b
  2. ericgibbs
    Jan 29, 2010
    2,581
    389
    hi,
    It is usual to have low value cap to 0v on either leg of the xtal, a 12pF thru 22pF is common.
    The other notes about resistors would depend upon the programs use of those pins.
    Note there are 'weak' internal pull up resistors on PORTB in the PIC, which can be enabled.
    If you are using the USB feature there should be cap on pin #18, Vusb to 0v, approx 0.47uF is common.
    I would advise that you fit 100nF caps across pins #11 and 12 and also pins #31 and 32.
    E
  3. NorthGuy
    Jun 28, 2014
    611
    121
    Your friend is right about capacitors. Have you ever looked at the datasheet? It has recommendations on the values of the capacitors depending on the crystal you use.
    Pins 31 and 32 must be connected.
    Your sketch shows resistors and capacitors, but doesn't show values. Wrong values can screw up everything.
    RA0 and port B - depends on what you do.
  4. 74266
    Mar 20, 2016
    41
    what should I do in RA0? I plan to use 100 ohms for each pin in PORT B, for the other resistors I want to ask for suggestion for their value cause this already my 3rd time to develop a board
    I will add a voltage regulator with capacitors,
    mini usb type - B,
    dc jack,
    and pin header for every pins in pic18
    also below is where I want to base it the components for the previous picture is also listed in there
  5. 74266
    Mar 20, 2016
    41
    Also can I ask for a schematic for a pic18f4550 with max232 with dc jack, mini type usb and db9 if you have some
  6. NorthGuy
    Jun 28, 2014
    611
    121
    If you connect PIC to MAX232, then simply connect direct. You don't need protective resistors inside your PCB. Just make sure they both run at the same voltage. This paper you linked has the schematics for MAX232, but it's sort of blurry and hard to read. You can look at MAX232 datasheet and they will have all the schematics. Datasheet is your friend. It has all the information, usually much more than you need.
    What is the purpose of the converter - talking to old modems?
    74266 likes this.
  7. 74266
    Mar 20, 2016
    41
    for the pin 2 of the max 232 should the positive part of the capacitor be connected in pin 2 at its negative part be in ground?
    also please check please these schematic I cant find out why it is not compatible to mplab
      File size:
      94 KB
  8. NorthGuy
    Jun 28, 2014
    611
    121
    MAX232: The capacitor on V+ has positive end connected to the pin. The capacitor on V- has negative end connected to the pin. Both go to the ground. It's all explained in the datasheet. Have you looked at it yet?
    Why do you think it's incompatible with MPLAB?
  9. 74266
    Mar 20, 2016
    41
    yes I have seen it but there are some schematic I saw in net that pin 2 is connected in vcc
    MPLab: in the dev board I made it is getting an error in every program I made
  10. ericgibbs
    Jan 29, 2010
    2,581
    389
    hi 7,
    Look at this image for MAX232, locate the caps as close as possible to the MAX, especially the one pin #16.
    E
  11. NorthGuy
    Jun 28, 2014
    611
    121
    What kind of error?
  12. 74266
    Mar 20, 2016
    41
    It is not being detected by the MPLAB even though the PICKIT2 app is detecting it
  13. 74266
    Mar 20, 2016
    41
    I just made a new dev board using my design but it has a problem again this time .My dev board was being detected by The PICKIT2 app but when I import the hex(In this hex it must only set the all the pins of RB) to test it but it was not showing an output. I just wanna ask for hel if you can solve this problem.
  14. jayanthd
    Member
    Jul 4, 2015
    275
    29
    If you have installed both MPLAB and MPLABX then you have to use MPLAB Switcher tool to select MPLAB if MPLAB X is selected.
  15. 74266
    Mar 20, 2016
    41
    I made another schematic can you please check if the connection and value of my components is correct?
  16. ericgibbs
    Jan 29, 2010
    2,581
    389
    hi 7,
    I cannot open that final.sch, what did you use to draw it.?
    E
  17. 74266
    Mar 20, 2016
    41
    I use eagle
  18. atferrari
    Jan 6, 2004
    2,663
    783
    I am sure the 18F4550 has weak pullup resistors in PORTB that you need to enable prior using. Maybe it could help. Ah, you enable all or none.
  19. ericgibbs
    Jan 29, 2010
    2,581
    389
    hi 7,
    Where are the connections to pin 15 and 16 . the power rails.?
    E
    EDIT:
    Also check your 9 way D connections at the PIC end of the cable.
    TX & RX ???
  20. TQFP44
    Sep 3, 2016
    25
    74 Is that 1 uF on the MCLR ? (C5) you can have .1uF but need to have a strap to disconnect it from the pin when programming ,
