PCB Design Layout Help
Discussion in 'The Projects Forum' started by the kidson, Jul 27, 2011.
  1. the kidson
    May 15, 2011
    32
    whats up all...thanks to everyone's help especially Sgt. Wookie..i finally got a working circuit that I am happy with...below is a diagram of the circuit how it appears on the breadboard...my power source is 9v...i am at the step now where i want to create a PCB..the problem is...i suck at drawing schematics and cant even figure how to start designing a PCB with the specifications needed..i would like to fit all this if possible onto a board that would measure to be 2" in length and about 1" to an 1 1/8" wide...the lights could be aranged however since they will have 10" of wire attached from the PCB..thanks in advance..and thanks for looking...the help is appreciated...here is the diagram of my circuit:
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
    Download diptrace and have fun with the tutorials..
    Or I'll do it. Prices start at $100 per hour (minimum charge of 5 hours).:)
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    There are some mistakes in the board.
    (see the notes in the drawing):
    Bertus
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You know, unless you practice on the skill, you'll continue to suck at it. :)
    Nobody starts off knowing this stuff. You have to work at it until you get even pretty decent.
    Radio Shack stocks this PCB:
    http://www.radioshack.com/product/index.jsp?productId=2102845#
    And PEBBLE has a board that's almost identical:
    So, why don't you give it a whirl?
    You don't have to place the IC's exactly how I placed them - that's just a suggestion to give you an idea how tight it's going to be.
  5. the kidson
    May 15, 2011
    32
    thanks for the replies...bertus...i seen your reply then did some reading to see why that was bad having the led's in parallel...so basically its just a matter of time when the leds will start acting weird with the current?..how would i resolve this?...by wiring them in series??..im confused about what you mean by " The resistor's right of the led's are shorted, as the contact lines are vertical (see red line)."..the circuit works...so im not sure what you mean...please forgive me and thanks for your patience...
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Each led should have its own current limiting resistor.
    Take a look at Bill_Marsdens thread on : LEDs, 555s, Flashers, and Light Chasers
    Post # 2 will tell you how to connect leds with the resistors.
    Bertus
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Here's an idea (rough draft) of what it could look like if you were going to etch your own board - but there's no need to do that with a project this simple.
