I want to know software for designing Led display board.
Please suggest which can generate Gerber file.
Are you saying that the maximum size allowed by Eagle is too small for your needs? If you don't want to pay extra to remove the size limit, you could use DesignSpark. Disclaimer: I have never actually had a board made from DesignSpark.It draw small size pcb that the big problem in it!
How does this flash BTW ??I made the 25 LED open end flasher in Eagle. The LEDs could not fit on a standard Eagle board, so I made several, and linked them together.
I used Bill_Marsdens desgin, but now I cannot seem to find it.
I just looked into the FreePCB, it does not appear to have a schematic editor? What formats does it accept?I have used FreePCB successfully a few times. It is fully functional (not a trial version) and outputs Gerber files.
http://www.freepcb.com/
Hello,I made the 25 LED open end flasher in Eagle. The LEDs could not fit on a standard Eagle board, so I made several, and linked them together
There is an integrated footprint editor which is simple to use.How easy to create new footprints?
Max.
I don't know; that information should be in the documentation.Hello,
i think this idea is fine but what is maximum length it can develop PCB?
