PCB design cost calculations
Discussion in 'General Electronics Chat' started by Vindhyachal Takniki, Jul 17, 2016.
  1. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    What is most used practice for PCB design cost calculation. I have designed a 310 mm x 170 mm board.
    Below are specs:
    Total number of pins: 899
    Pins in a net: 899
    Not connected pins: 0
    Test pins: 0
    Jumpers: 0
    Total number of vias: 185
    Total number of connections: 651
    Unrouted connections: 0
    Completion: 100%
    Total number of parts: 285
    Total number of nets: 253
    PCB size: 310mm x 170mm
    No of layers: 2
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
  3. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    I have designed it in ultiboard. So I am asking how to calculate its cost so that I can quote it to client.
    Not for manufacturing.
  4. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,701
    1,300
    If you are talking about the cost to fabricate a bare PC board, many board houses have online calculators for instant quotes. This one gives prices at several quantity breakpoints (that you set) for both quick-turn prototypes and standard-turn production runs.
    http://www.4pcb.com/
    ak
  5. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    If not for production is this a one-off for a client?
    Do you intend to make it yourself?
    Otherwise any PCB house will require at least a x5 minimum.
    Max.
  6. SLK001
    Nov 29, 2011
    852
    243
    I charge by the hour. How long did it take you to design the board? Multiply that by your going rate and send the bill to your client.
  7. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    You do not show your C.o Origin so it depends what the market will bear and also competition, if any.
    Also depends on whether you are very proficient and/or familiar with the design S/W.
    Here, for a task like this that I consider a good level of proficiency with would cost ~$80.00/hour rate, min.
    Max.
  8. SLK001
    Nov 29, 2011
    852
    243
    You're kinda upside down on this. You have already invested the time and effort to design the board and now you want to quote it to a client? What if he says that he no longer wants the board? What if he dramatically redefines the scope of the project? In both cases, you're screwed.
