PCB design and simulations
Discussion in 'General Electronics Chat' started by Anders Hansson, Mar 20, 2016.
Thread Status:
Not open for further replies.
  1. Anders Hansson
    Mar 20, 2016
    When designing a circuit board there are many common questions like;
    - How should I think when doing a proper grounding for my PCB?
    - Will I run into signal integrity problems when I distribute the clock on the board?
    - What is ground bounce?
    /Anders
    Mods edit:
    Our site does not allowed any kinds of site promotion on thread, otherwise we will treat it as spam and delete the thread and mods team decided to close the thread.
    If you wish to stay on this site then you can share your knowledge of pcbs designing to help our members.
  2. SLK001
    Nov 29, 2011
    848
    241
    #1) Make your ground as low in impedance as you can. High impedance grounds are the cause of most PCB related problems.
    #2) Quite possible. That's why differential signals are used to keep common mode interferers to a minimum. Good grounding also helps keep your clocks clean - see #1, above.
    #3) Ground bounce is when ground potential in one area of your PCB is different from another, on an instantaneous basis. For instance, an amplifier will usually be the largest current consumer on the PCB. When the amp has a high excursion signal, the ground potential will rise and fall. When this rise and fall gets to the more sensitive parts of the PCB, a disruption of the signal integrity will occur due to this "ground bounce". A low impedance ground will mitigate this effect - see #1, above. Also, routing your grounds in a "star" pattern will keep a lot of the bounce out of your circuitry.
  3. GopherT
    Nov 23, 2012
    6,297
    4,019
    Why don't you bring your squad over here and start a thread or ask the Moderators to start a sub forum on PCb design.
  4. Anders Hansson
    Mar 20, 2016
    You have a good point of course.
    My primary interest is to create a blog for electronic designers that find my contribution to electronics valuable. My main focus is digital and analog audio designs, so many people comes from that kind of forums even if there are general interests as well.
    /Anders
  5. Anders Hansson
    Mar 20, 2016
    Thanks for your comments!
    On #2) I agree with you. Low impandance grounding is good the signal integrity in general. Any comments to my post regarding clock distribution?
    On #3) Oh... maybe I should have pointed out that when I talked about ground bounce I refered to the change of voltage potential at the chip ground with respect to the ground of the PCB. I have actually not heard about using the term ground bounce at PCB level - I learned some today :)
  6. ScottWang
    Aug 23, 2012
    4,924
    777
    You already have your personal blog space on this site when you completed the registration, you just click on your id and you can post any ideas about pcbs over there.
    When you discuss the pcb with members, if you have any related subject that you posted in your blog then you can post the links to the thread.
  7. Anders Hansson
    Mar 20, 2016
    Thanks for the info. I took a look into the personal blog section, but for some reason I don't have permissions to write any posts.
  8. ScottWang
    Aug 23, 2012
    4,924
    777
    Probably the system has 10 posts limited, when your posts over 10 then try it again.
Thread Status:
