PCB copper oxidation
Discussion in 'The Projects Forum' started by Garurumon, Sep 6, 2013.
  1. Garurumon
    Mar 17, 2013
    99
    I'd like to protect my finished PCB's from corrosion, but I do not have access to any PCB plating sprays and stuff.
    I heard that some people practice puting the flux all over the board to protect it. Now, I have a bunch of rosin (colophony), but I don't know how to disolve it :D
    When I use it, i just dip the tip of my iron in it, and then continue soldering.
    Anyone knows if flux protection is effective, and if yes, how to dissolve colophony and apply it over PCB copper?
  2. kubeek
    Sep 20, 2005
    4,687
    805
    You can crush the rosin into fine powder and then dissolve it in isopropyl alcohol, but i don´t think that rosin is a good way to impregnate your boards, the layer will tend to stay sticky for some time so it will gather all the dust from around.
    Try looking for some conformal coating spray or similar pcb laquer.
  3. Garurumon
    Mar 17, 2013
    99
    well, the projects goes into the sealed box right away :)
    but rosin would prevent oxidation?
  4. mcgyvr
    Oct 15, 2009
    4,787
    973
    Conformal coating spray? (about $25.00 a can)
    tinning of the traces?
    polyurethane varnish?
    There are plenty of products that "could" be used.. Flux is not one I would ever choose. (mostly because its going to be UGLY)
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
    Spray urathane lacquer over the board.
  6. Garurumon
    Mar 17, 2013
    99
    would acrylic work?
  7. MrChips
    Oct 2, 2009
    12,624
    3,451
    Yes. But if you want better protection, use conformal coating.
  8. joeyd999
    Jun 6, 2011
    2,756
    2,916
    There are electroless tin plating solutions available. Just dip your board in the solution, and you done.
    Oh...you need to do this *before* populating the board.
    PS -> this is how I did it when I was a kid (~10 y.o.).
  9. #12
    Nov 30, 2010
    16,665
    7,310
    I use Krylon Clear. But then, I don't know if you can buy Krylon in the country where colophony is a well known word.
  10. bountyhunter
    Sep 7, 2009
    2,498
    507
    Use clear urethane spray. Buy it at any Home Depot.
  11. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    +1 on the Conformal C.
    Max.
  12. DickCappels
    Aug 21, 2008
    2,755
    665
    I know a guy who spray paints his boards different color. I agree with #12: "If you prize it, Krylonize it."
    Flux is a bad idea, many fluxes are poor insulators.
  13. GopherT
    Nov 23, 2012
    6,303
    4,019
    What the hell, did #12 get a promotion? Why didn't it get posted somewhere? What is his new title (what was his old title)?
  14. kubeek
    Sep 20, 2005
    4,687
    805
    If he got a promotion, shouldn´t he become #11?
  15. GopherT
    Nov 23, 2012
    6,303
    4,019
    Good point. There is obviously some sort of scandal, confusion or typographical error going on and someone should get to the bottom (or top) of this!
  16. sirch2
    Jan 21, 2013
    1,008
    351
    Genuine question: is conformal coating really much better than other paints and lacquers? I've coated a few boards with clear lacquer intended for things like alloy wheels and it seems to work fine, what advantages does conformal coating have?
  17. DickCappels
    Aug 21, 2008
    2,755
    665
    I have corrected the inadvertent demotion of #12. Thanks for catching the typo.
    Lacquer is a conformal coating. What kind of conformal coating do you wish to compare lacquer?
  18. sirch2
    Jan 21, 2013
    1,008
    351
    The stuff available from car parts shops for £5.00 against the stuff called conformal coating sold by electonics parts suppliers for £15.00
  19. kubeek
    Sep 20, 2005
    4,687
    805
    It could be that the electroincs stuff is carefully tested so that no aggressive chemicals leach out of it over long time periods (say 20-30 years), that it´s parameters like resistivity and permittivity are known and controlled, and maybe some other aspects too.
  20. sirch2
    Jan 21, 2013
    1,008
    351
    I guess that could be it
