PCB Burning from Hot resistors
Discussion in 'General Electronics Chat' started by RodneyB, Dec 12, 2014.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    648
    14
    I have attached a picture of a PCB that I have which is burning from the heat generated by the resistors. Is there any way of protecting the PCB from burning.
    I was thinking about putting aluminium foil under the resistors but needed conformation and then that also comes with a set of its own problems.
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    RodneyB likes this.
  3. #12
    Nov 30, 2010
    16,676
    7,320
    You can also buy resistors that don't run so hot per watt, or just buy over rated resistors like 5W rated in a 3W position. I recognize that particular shape as a resistor that can survive higher temperatures...but the circuit board can't!
    RodneyB likes this.
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  5. #12
    Nov 30, 2010
    16,676
    7,320
    Yes. There are several ways to get bulkier resistors, some round, some square. What I wanted to emphasize is the ends being larger than the resistor body and that light grey background color indicating the, "run hot" resistors.
  6. mcgyvr
    Oct 15, 2009
    4,789
    974
    Resistors should always be sized at 2 to 3 times the required wattage and then keep them off the board by 1/8" or more.
    That should be more than sufficient.
    RodneyB likes this.
  7. alfacliff
    Dec 13, 2013
    2,449
    428
    if thbere are no pc runs under the resistors, drill some holes in the fiberglass for ventilation. also, if you have replacement resistors, mount them on longer leads to space them above the board.
  8. sheldons
    Oct 26, 2011
    616
    101
    All good advice but as the circuit is just powering leds there should never be that much heat generated resistor wise to burn the board in that way if the resistor value/wattage has been properly worked out with reference to the supply voltage available. ....are these ran direct from mains ? What is the mystery supply voltage used ??? You could fit slightly higher wattage resistors and space them away from the board a little.....
  9. ErnieM
    Apr 24, 2011
    7,436
    1,626
    If you look carefully at the picture the annular rings for the resistors also show discoloration. This is due to the leads themselves conducting heat out of the resistor into the board. Spacing the body of the part will only help a little with that issue.
    The pads should be greatly increased in size to large copper masses to aid in heat dissipation. These pads should be of the "thermal via" type that isolated the pad a bit from the mass so you can still solder to it.
  10. MrChips
    Oct 2, 2009
    12,625
    3,451
    I think the issues are very obvious:
    1. PCB is charred
    2. Resistors not rated for proper power dissipation
    3. Solder joints will deteriorate
    You are powering the LEDs from AC mains, correct?
    That is a violation of the Terms of Service (TOS) of All About Circuits and further discussion along those lines will result in this thread being closed.
  11. BobTPH
    Jun 5, 2013
    806
    121
    I doubt that it is powered from mains as the resistors appear to be 100 Ohms.
    Bob
  12. sheldons
    Oct 26, 2011
    616
    101
    There's diodes there too(1N4007 ?)......still shouldn't be running hot as they are only driving leds....so....what is the supply voltage used???...
