PCB board design for a Stepper Motor
Discussion in 'The Projects Forum' started by jfeeney, Jul 18, 2008.
  1. jfeeney
    Jul 14, 2008
    14
    http://www.piclist.com/techref/io/stepper/linistep/index.htm
    Is the Linisteppe Stepper Motor controller a good design.
    I am just learning about MicroControllers and PCB boards. I have recently purchased the PICKit 2 to learn programming.
    My goal is to learn how to design a stepper motor project. I am looking for a good model to follow in terms of programming, PCB board design, etc.
  2. Pich
    Mar 11, 2008
    119
    It's a nice controller, look at the link "how it works" on the web site it will guide on what motors to use
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It's interesting. I haven't had time to analyze it completely.
    The real question is, what kind of project are you contemplating?
    Do you really need that much of a driver?
    You can do a lot with smaller "pancake" type motors like a PF35T-48L4 and ULN2803A's.
    http://www.jameco.com/webapp/wcs/st...toreId=10001&catalogId=10001&productId=171601
    http://www.jameco.com/webapp/wcs/st...storeId=10001&catalogId=10001&productId=34315
    Decent and cheap for learning and small projects.
    However, if you're going to build a CNC mill or the like, you'll need something more heavy-duty like the Linistep.
  4. jfeeney
    Jul 14, 2008
    14
    I am going to use this as my guide for now.
    I think I do need that much motor. I want to build something that will do some pick and place.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    In that case, it would be a good choice.
    A pick & place machine is pretty ambitious for a 1st stepper project. I'd be interested in hearing about your progress.
  6. jfeeney
    Jul 14, 2008
    14
    It is ambitious, but sometimes it is easier to go where your heart drives you.
    I think if I can get a look at the big picture then break it down in chunks. Take one chunk and learn about it.
    I don't care if I buy a kit -- as long as I understand each part.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, just so you know - those boards are really designed to be driven using software on a PC and interfaced via a parallel port (think LPT1: ) but you could probably drive it using a PIC. Like I say, I haven't researched it that much.
    Many computers are now being sold without either RS232 or LPT1; instead they're using 100baseT and USB. However, you can always get a multifunction card and plug it in a vacant PCI slot - if you have one available.
