PCB and engraver boards
Discussion in 'The Projects Forum' started by knowtankyou, Mar 6, 2016.
  1. knowtankyou
    Feb 29, 2016
    32
    I have access to a high end engraver that we use to make nameplates for our projects.
    I want to use this to make my PCB.
    My project is simulated in LTspice and has a 555, a npn, FET, 2 diodes, and various capacitors and resistors.
    I will have terminals for the off board LED, input power and off board potentiometer.
    I read on this forum somethings good and bad about expressPCB
    however, my main question is regarding how an engraver produced PCB will change the output from a PCB software package.
    thank you
  2. DNA Robotics
    Member
    Jun 13, 2014
    132
    33
  3. knowtankyou
    Feb 29, 2016
    32
    so what is the best way to go from LTspice to PCB in general, I imported my netlist into expressPCB and I can not create a rats nest from the netlist.
    any suggestions are appreciated on how to get into any PCB cad file. then I can worry about how to make the traces into toolpaths for the mill.
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
  5. DNA Robotics
    Member
    Jun 13, 2014
    132
    33
    I don't use LTspice. From all the questions I see on forums, I get the impression that it just adds a whole new layer of problems.
    ExpressPCB is great & so is their free program but they don't want you sending boards to their competition. I don't think you can get G-Code from their layouts.
    I design & layout boards in Eagle 6.4.0 and use "pcb-gcode-3.6.0.4" to generate single pass G-code to engrave & drill with Mach3Mill. It isolates the traces & leaves unused areas alone. You can use those areas as ground plane if you like.
    Does your engraver use Mach3?
  6. knowtankyou
    Feb 29, 2016
    32
    So I imported the LTspice model and now I can't seem to change the package.
    I am stuck with incorrect packages for the diodes and the MOSFET.
    when I right click in Eagle and try to change the package but its not editable.
  7. jpanhalt
    Jan 18, 2008
    5,699
    909
    You need to go to the libraries, then set up an alternative package as alternative "technology." Eagle easily allows alternative packages, but not alternative symbols.
    John
  8. knowtankyou
    Feb 29, 2016
    32
    First off, thank you all to the people who have been so helpful. I appreciate all the input and feedback.
    is there a series of Youtube videos that someone might suggest for specifics on PCB board design specific to Eagle CAD
    I intend to make these myself, so Express PCB is a non-starter if it can't export.
    to be blunt, I can buy a PWM LED driver from Ebay, it's not about the thing, it's about learning the process.
    Thanks again and have a great night.
  9. knowtankyou
    Feb 29, 2016
    32
    PS, in eagle I had the option to select parts that had cost and package information, which was great.
    however when I made my "shoping list" it didn't feed back to the parts on the board. When I picked a TO-220 FET, i still had an SMD23 in the board.
