PC USB Oscilloscope
Discussion in 'Electronics Resources' started by RodneyB, May 30, 2013.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    654
    14
    I am looking for some advice on purchasing a PC USB oscilloscope. I have no idea what to look for and what to order. Can I have some guidance? I looked on e bay and they range from US$22.00 to thousands so really don’t know what to look for. If someone could suggest a reasonable entry level unit I would be most grateful.
    Secondly I have Brunelle CRT oscilloscope which I would like to learn to use. Can someone direct me to a site which has step by step instructions for a beginner.
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    If you have a functional CRT oscilloscope at home I 'd suggest you didn't buy a PC USB one.
    The extra things the USB oscilloscopes provide (depending on model) is logic analyzer function and waveform capture. If you do need those things, then, yes, a USB o'scope purchase is justified.
    RodneyB likes this.
  3. RodneyB
    Apr 28, 2012
    654
    14
    Problem is I have no idea how to use it
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    Well, start by telling us which model it is.
  5. RodneyB
    Apr 28, 2012
    654
    14
    It Just says Brunelle Instruments on it no model number it is a2 channel oscilloscope
  6. Georacer
    Nov 25, 2009
    5,151
    1,266
    No label or number anywhere? Not even in the back?
  7. LDC3
    Apr 27, 2013
    920
    160
    If you don't need anything above 40 kHz, then you can use the free program WinScope. It uses the mic in on the sound card to capture the information.
  8. OoglieBooglie
    Jun 3, 2013
    21
    I second this. I found a different free program simply called 'Scope' and it does the same thing. Beats paying hundreds of dollars for a bulky thing to sit on your desktop.
  9. w2aew
    Member
    Jan 3, 2012
    219
    64
    There's a sticky thread in this section that includes a link video on the basics of oscilloscopes.
    http://forum.allaboutcircuits.com/showthread.php?t=64241
    There are dozens more oscilloscope (and other tutorials) on the same YouTube channel
    Http://www.youtube.com/w2aew
