PC to TV Converter
Discussion in 'General Electronics Chat' started by HallMark, Sep 16, 2011.
  1. HallMark
    Apr 3, 2011
    89
    5
    Hello Friends,
    I want to Connect my PC to TV instead of LCD. And my TV Supports only AV type Connector I tried to connect it with one converter available in market but i was not able to find the fault so now i think there must be any circuit and i want to give it a try by myself.
    Can anyone please give me more detailed circuit?
    Waiting for Reply.
    -HallMark
  2. debjit625
    Apr 17, 2010
    790
    186
    The main problem in this conversion is the resolution as your computer's video adapter will output different resolutions and most of them are not supported with your TV.Televisions have really low resolution compared to monitors but modern HD TV gives you a very high resolution.Any way what converter you are talking about I have no idea, but it's simple you just need a graphic card which can output AV signals.
    And about the circuit ,I have created AV and VGA signals using mcu but never converted VGA to AV.You may google a bit.
    Good Luck
  3. tom66
    May 9, 2009
    2,613
    214
    It is possible, but you need a resolution of 720x576 or 720x480, interlaced, which most graphics cards do not output.
    Some graphics cards have S-video output. This will work with any television.
    Most LCD TVs come with a VGA connector which can be used to connect directly to the PC.
  4. HallMark
    Apr 3, 2011
    89
    5
    I tried the device available in market locally but it not working OK. So serching for another Circuit.
  5. tgotwalt1158
    Member
    Feb 28, 2011
    111
    18
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    HallMark likes this.
