PC to PLC communication
Discussion in 'General Electronics Chat' started by pandian, Apr 12, 2010.
  1. pandian
    Thread Starter Active Member
    Sep 27, 2009
    32
    I wich to connect my PC (with CX-one programmer) to supported PLC (Omron) and HMI. The mentioned PLC has a peripheral port.
    What cable is suitable for this connection?
    Thanks.
  2. rjenkins
    Nov 6, 2005
    1,015
    69
  3. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    likely ethernet/IP, but I do know that USB is used as well. Going a while back, R232 was common.
  4. pandian
    Sep 27, 2009
    32
    My new laptop doens't carry a RS232 port. So i have to use USB to RS232 converter. How many types of converters is there? Or is it only one type?
  5. retched
    Dec 5, 2009
    5,201
    313
    No there are many. You have to be sure the one you get will report to the proper pins on the rs-232 side. Some are not 'straight thru' devices. The computer must be using a proper driver for the device also.
    I have found 1 that is..:
    http://www.amazon.com/dp/B0006LSIOI/ref=oss_product
  6. kingdano
    Member
    Apr 14, 2010
    377
    19
    another thing to watch out for is required use of handshaking for rs-232 devices
    a lot of usb-serial converters do NOT allow for manipulation of these pins and can leave you frustrated wondering why things arent working.
    your best bet is to try the suggested converter out - and if things arent working you may need to invest in a serial comms card for your PC.
