PC power supply as bench power supply
Discussion in 'General Electronics Chat' started by xxxyyyba, Nov 19, 2015.
  1. xxxyyyba
    Aug 7, 2012
    249
    What do you think about converting pc power supply to bench power supply?
    Is it ok for amateur use?
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,379
    651
  3. MrSoftware
    Oct 29, 2013
    545
    133
  4. xxxyyyba
    Aug 7, 2012
    249
    Does PC power supply contains short circuit protection?
  5. wayneh
    Sep 9, 2010
    12,391
    3,246
    Yes, usually.
  6. AnalogKid
    Aug 1, 2013
    4,701
    1,300
    Most PC supplies have enough power to run most home hobby electronic stuff. But the current limits are set way too high to protect most things. If you are firing up a preamp circuit or an Arduino thingy with a wiring problem, having a supply with the current limit at 20 amps is not going to protect your circuit. Also, neither the voltage nor the current limit levels are very adjustable, if at all. Finally, the output noise usually is at the max possible limit for what a computer can handle, and can cause problems for just about anything else. There is a lot of cheap, regulated power, but it has some serious baggage.
    ak
    xxxyyyba likes this.
  7. Dodgydave
    Jun 22, 2012
    5,156
    772
    I have made several of these Atx psus variable by modifying the pwm feedback, giving a voltage range of 1.9 to 28V @22 amps...its a matter of finding which chip is used in the atx.
    http://danyk.cz/s_atx_en.html
  8. AnalogKid
    Aug 1, 2013
    4,701
    1,300
    True, but given the OP's self-description and the general content of his other posts, my guess is that such surgery is beyond his skill set.
    ak
    Dodgydave likes this.
  9. Hypatia's Protege
    Mar 1, 2015
    2,848
    1,317
    Be advised also that stable, reasonably low noise, operation of PC PSUs requires a minimum load...
    Best regards
    HP
  10. AnalogKid
    Aug 1, 2013
    4,701
    1,300
    Darn those 99 cent magnetics...
  11. wayneh
    Sep 9, 2010
    12,391
    3,246
    A great first project is to build yourself a LM317-based power supply with the input coming from an old PSU. The LM317 gets rid of the noise from the PSU and can handle plenty of juice for lab bench projects. And it will shut itself down if your project shorts.
    Hypatia's Protege and xxxyyyba like this.
  12. Hypatia's Protege
    Mar 1, 2015
    2,848
    1,317
    Ok, I give up -- To what does "99 cent magnetics" refer?:)
  13. AnalogKid
    Aug 1, 2013
    4,701
    1,300
    Minimum load requirements caused by undersized, low quality, ultra-low cost magnetics. OK, that and no internal minimum load resistor.
    ak
    Hypatia's Protege likes this.
