PC Monitor Repair
Discussion in 'Computing and Networks' started by aceMan, Mar 28, 2004.
Thread Status:
Not open for further replies.
  1. aceMan
    Mar 27, 2004
    Hi guys,
    First of all a wonderful site for learning abt electronics and great forum.
    Well I would like to know a good website to learn about the insides of the pc minitor, as in explains everypart of the insides of the monitor.
    Because I have a monitor which works now and then. It keeps clicking and clicking till it scares everyone using it.
    I would like to know about the monitor before attempting to repair myself.
    Any good links?
    I will come back here to ask if I am stuck halfway.
    Thx
    Vijay
  2. SteveYTI
    Member
    Feb 9, 2004
    23
    I am not sure i have any good links for you... I repair old CRT based monitor systems here where I work all the time and it is not very easy on the heart. There is high voltage made in there and the warnings and cautions that speak of the circuitry retaining the capability of a HV shock should be understood before you proceed. If its new know that computer monitor manufacturers are using more digital equipment now than before. Just be careful I guess is the best advise
  3. Graham
    Member
    Sep 10, 2003
    22
    I have no experience with monitor repair.. but I do know it can be VERY dangerous. Be very careful if you do decide to give it a try.
    I did a search on google and found this forum you should post your question on.. It seems semi-active.
    http://www.network54.com/Hide/Forum/87612
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    More bad news. The noise is probably the spark gap capacitors arcing over. They are usually green, with a small slot in them (the spark gap). They are there to prevent overly high potentials between elements in the crt.
    After trying to do such repairs in a major university electronics shop, we abandoned the effort as just too much trouble. The engineering runs everything right at the limits, so any problem usually results in a cascade of failures.
    Try Computer Geeks. You can probably get a larger monitor that works well for less than the price of the repair parts. Monitors are very hard to get to internally, and designs vary all over the place. They all work alike, but do it differently in terms of components used.
  5. vikasbly44
    Jan 19, 2015
    13
    i have no experience regarding this problem.. but if you try himself, then it may be dangerous. so, try carefully.
  6. shteii01
    Feb 19, 2010
    3,500
    511
    CRT is hard.
    LCD is easy. Most times just need to replace capacitor(s) on the power supply board.
  7. MrChips
    Oct 2, 2009
    12,624
    3,451
    Old thread. Now closed.
Thread Status:
