PC Fan RPM sensor?
spinnaker
Joined Oct 29, 2009
7,830
So I am messing with a PC fan and the RPM sensor, I might want to use it for a propeller clock project.
I am powering the PC fan with my bench top power supply at 12V. I placed my scope probe on the RPM sensor pin
And I get this.
What are those spikes? How can I eliminate them?
From what I read, you need to pull that senor pin high but it looks like that is not the case.
ronv
Joined Nov 12, 2008
3,770
Only a guess. I think they may just be using the coil voltage and the spike is the inductive kick. You could run the signal thru a resistor and then clamp it at 12 volts with a zener or a diode clamp to +12.. Then feed that to your logic.
spinnaker
Joined Oct 29, 2009
7,830
Wouldn't I clamp at 5V? That is the voltage I want to feed into my pic.
Reloadron
Joined Jan 15, 2015
7,523
Years ago when I experimented with this stuff I used a 10K pullup resistor on the fan speed output. Pretty sure the tach out signal is open collector. I also think the output is two pulses per revolution. Your pulses look to have hign frequency accentuation on the leading edges. Are you using a scope probe and is the vertical coupling set to AC or DC? If you are using a probe like a 10X probe you may want to check the probe compensation.
This is an old dead web page and while a mess it does have whats left of some of my images from when I experimented with fans and fan speed control years ago. The page is no longer even a part of the web but sitting on the server. You may find something in the mess. :)
Ron
Reloadron
Joined Jan 15, 2015
7,523
I see I missed a few post while I slowly typed. If you want 5 volt pulses run the fan on 12 volts and use a 10K pullup but apply 5 volts on the pullup resistor. You have 5 volts from the PIC correct?
Ron
ronv
Joined Nov 12, 2008
3,770
You could try slowing it down with your finger. If the amplitude goes down it is probably just a back emf sensor.
Me to. But it looks like he already has 10 or 11 volts.
spinnaker
Joined Oct 29, 2009
7,830
Ron
This must be an older fan. It has a blue wire and most fans have a yellow wire. If I add a 10K pullup, I get a small signal riding on 5V along with the higher voltage spikes.
I did find a circuit that runs the output through a 2n2222 and clamps that output with a 5.1v zener.
spinnaker
Joined Oct 29, 2009
7,830
Ron
I just want 5V out. I don't want those spikes to fry my pic.
Reloadron
Joined Jan 15, 2015
7,523
Yeah, they were old fans also 3 wire fans. I did that about 10 to 12 years ago. The tach out was white and on some fans yellow. The newer fan specification reads:
Pin Function Wire Color
1 GND Black
2 12 V Yellow
3 Sense Green
4 Control Blue
I understand the spikes that concern you. Earlier I asked if with your scope you were using a probe and if the probe was correctly compensated to the scope's vertical input channel? The spikes may be a result of high frequency accentuation in how the scope probe is coupling the signal to the scope. In other words what you see on the scope may not be what you actually have.
Ron
spinnaker
Joined Oct 29, 2009
7,830
1 GND Black
2 12 V Yellow
3 Sense Green
4 Control Blue
Ron
I am using a 1x probe DC coupled.
Reloadron
Joined Jan 15, 2015
7,523
Well the 11 volts makes sense but the spike doesn't. These fans generally use two hall effect sensors and output two pulses per revolution. The hall sensors generally drive a NPN transistor which is open collector. I have heard of open drain but never saw it. Since the probe is X1 the spike should not be caused by a compensation issue. If you have a X10 probe you may want to try it and set the vertical gain for 0.5 V/Div and see if the spike still exist. You can also try AC coupling and while that will not show any DC offset let's see how the pulses look.
Ron
ronv
Joined Nov 12, 2008
3,770
I think I have seen this before. The coils are tied to +12 and the bottom side switched by a NFET rated at like 20 volts. When the FET turns off the inductive kick goes high and the FET goes into avalanche breakdown clamping it. The rest of the signal is motor back emf on the open coil. If you slow it down the 11 volt part will drop. Right now it looks like 2500 RPM. At 1250 it would be 5.5 volts. I think you can just run it thru say a 5k resistor and clamp it with a little schottky diode.
spinnaker
Joined Oct 29, 2009
7,830
This is with 10X and AC coupling. My scope compensates display for the 10x setting.
Looks like the spikes are still there.
Not a big deal, I could always get another fan. Just curious as to wahy this is occuring.
spinnaker
Joined Oct 29, 2009
7,830
You can tell the RPM just by looking at the voltage??
I would connect the anode of the diode to ground? Won't I need a zener? Or at least a voltage divider?
Reloadron
Joined Jan 15, 2015
7,523
I tend to agree with Ron. The fan speed is being controlled by PWM with the low side switched. I guess if really curious you could remove the fan power and just power the fan from 12 VDC without any PWM and look at the tach output using an external pullup and see what you get. Beyond that I would do as Ron suggest. I never saw it but Ron's explenation makes good sense to me.
Ron
spinnaker
Joined Oct 29, 2009
7,830
Ron
Fan is not being controlled by PWM. Just straight 12V.
bertus
Joined Apr 5, 2008
22,278
The 10X scope probe has a very high input impedance.
Try to put a resistor as load on the RPM connection to ground.
A value of 1 - 10 K and see if there is any difference.
Bertus
