PC boot problem
Discussion in 'Computing and Networks' started by AHMARAFAH, Feb 18, 2007.
  1. AHMARAFAH
    Jul 11, 2006
    20
    can anyone answer this question?
    what is the most common cause of this message at boot up? "NTDLR is missing, press any key to restart!
    many thanks
    ahmed arafa
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Most probably some rubbish software wiping the Windows boot partition or an issue relating to replacement of some core hardware, e.g. a hard-drive.
    Dave
  3. AHMARAFAH
    Jul 11, 2006
    20
    Thank you Dave.Can you please,post the procedures how to fix this problem?
  4. n9352527
    Oct 14, 2005
    1,198
    It's most probably ntldr and not ntdlr. If you have the CD, then you could do a repair. Boot with the CD, and follow the installer until there is a choice between install and repair current installation.
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Assuming you have Windows XP, like n9352527 says you can boot using the XP cd and go to the recovery console. You should look at the Microsoft knowledge-base article on this error (ref: http://support.microsoft.com/kb/318728/), this is for Windows 2000, however it is likely that it will be applicable to Windows XP.
    I personally cannot comment because I have never come across this issue, but this website provides a range of methods for over coming this issue - I suggest you work through the MS knowledge-base article and the ideas from the above site and try one of the methods available.
    Dave
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
  7. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
  8. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    There's always one!!
    Considering I have never heard about this problem before, I seem to be seeing a lot of this very issue rearing its head across the Internet, has something happened that we should be aware of? Or is it just coincidence?
    Dave
  9. alitex
    Mar 5, 2007
    122
    you can check your ram's memory if it has any problem it give u queer messages during boot
  10. playstation.aneesh
    Jan 8, 2008
    47
    copy ntdetect.com and ntldr from the windows xp cd....first boot the comp with cd ,,then get into the recovery console..
  11. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It's a good idea to look at dates - this thread started up last year.
  12. playstation.aneesh
    Jan 8, 2008
    47
    lol lol lol
    didnt notice it
  13. sharkfire
    Member
    Feb 13, 2008
    23
    Are you using laptop? I've got the same problem too. We had my laptop reformatted. And everything went back to normal.
    I think, some spare parts inside the machine was moved or something.
