Hi all. Have a few schematics to layout to a PC Board. Have purchased the 276-150 board from The Source (Radio Shack north of the 49th!):
and would like to know if my assumptions are correct on how to organize the components on it.
The 2 long strips in the middle would be for the power: negative on one strip and positive on the other. Any components that need direct connections to the power would start there. (I have 8 OPB704 IR sensors, so will need 8 - and 16 + connections for those alone!)
The dual-hole pads on the edges should be used for components that need input or provide output: the component connects to the inside hole and a wire to the external device is soldered to the outside hole.
The triple pads can send one component's output to 2 other components' inputs.
So, what's confusing me are the single-hole pads - what is their purpose?. If, for instance, I insert a resistor's lead into the hole, how does that then connect to another component? Do I connect a wire between the leads before soldering? Do I use a silver trace pen to draw my own connections between holes (which I assume I would do before soldering)? Or do they have a specific purpose to remain single?
Any tips greatly appreciated!
