PC-Based Oscilloscope
Discussion in 'General Electronics Chat' started by Sonoma_Dog, Sep 11, 2008.
  1. Sonoma_Dog
    Thread Starter Active Member
    Jul 24, 2008
    99
    Hi all, I wanted to buy an oscilloscope, but I can't really afford a real one at this moment. So i am thinking to purchase a PC-based oscilloscope, does anyone know a good brand for a pc-based oscilloscope?
    and what are some of the disadvantage of PC-Based oscilloscope, beside it doesn't comes with a pretty screen.
  2. Sonoma_Dog
    Jul 24, 2008
    99
    Ah, after talking to my friend wikipedia. here are some of the disadvantage of PC-based oscilloscope.
    • Power-supply and electromagnetic noise from PC circuits, which requires careful and extensive shielding to obtain good low-level signal resolution.
    • Data transfer rates to the PC, which are dependent upon the connection method. This affects the maximum sampling speed achievable by the PCO when streaming.
    • Need for the owner to install oscilloscope software on the PC, which may not be compatible with the current release of the PC operating system.
    • Time for the PC to boot, compared with the almost instant start-up of a self-contained oscilloscope (although, as some modern oscilloscopes are actually PCs or similar machines in disguise, this distinction is narrowing).
    have anyone used a PC-Based Oscilloscope and experiencing any noise problem and time delay on the data streaming from the O-scope to PC? And how bad is it?
  3. studiot
    Nov 9, 2007
    5,005
    515
    You have lots of options using a pc but you are right, there are cons as well as pros.
    You haven't said what you are going to use your scope for. this is very important as it will determine the frequency range (and price).
    You can get digital multimeters with pc output. These include slow speed scope diaplay software. See ref 3
    For somewhat more money you can get handheld 'scopes' with pc output for larger screen. (ref 2)
    Or you can get some pretty comprehensive pc base multi instruments. (ref1)
    Of course some modern scopes have printer and pc output of their own.
    http://www.fastsampling.com/DDSG2AManual.pdf
    http://www.uni-trend.com.hk/UT81B.html
    http://www.maplin.co.uk/Module.aspx?ModuleNo=46381&DOY=4m9
  4. The Electrician
    Oct 9, 2007
    2,300
    335
    How much money can you spend?
    What performance do you need, such as bandwidth?
    How many channels must you have?
  5. Sonoma_Dog
    Jul 24, 2008
    99
    regarding the performance, i don't need a huge bandwidth, 20Mhz will do. And at least 2 channel.
    The price have to be as low as possible. ;)
    Something like what studiot have mention, (http://www.fastsampling.com/DDSG2AManual.pdf) This would be ideal, the price is reasonable too, but is there anything else that is cheaper? :)
  6. The Electrician
    Oct 9, 2007
    2,300
    335
