pc based digital clock via parallel port using assembly language in tasm
Discussion in 'The Projects Forum' started by maonin, Oct 15, 2011.
  1. maonin
    Oct 15, 2011
    hi, i have this project and we already have a code and the circuit but it is not working..
    it's supposed to display the hours and minutes
    the problems are:
    1. the hour display is not displaying anything
    2. the minute displays but it is advanced by one minute
    so here's the code:
    Code ( (Unknown Language)):
    1. TITLE CLOCK.ASM
    2. DOSSEG
    3. .MODEL SMALL
    4. .STACK 0100H
    5. .DATA
    6.       PRINTERPORTBASEADDRESS equ 378h
    7. .CODE
    8.  MAIN        PROC
    9.       MOV AX, @DATA
    10.       MOV DS, AX
    11.
    12.       CALL RTIME    ; READ TIME
    13.       CALL DisplayTime     ;DISPLAY TIME
    14.
    15.       MOV AX, 4C00H
    16.       INT 21H
    17. MAIN         ENDP
    18.
    19. RTIME         PROC
    20.       MOV AH, 02H
    21.       INT 1AH
    22.       RET
    23.
    24.       ; CH - HOUR
    25.       ; CL - MINUTES
    26.       ; DH - SECONDS
    27. RTIME        ENDP
    28.
    29. DisplayTime PROC
    30.       push     DX
    31.       push     CX
    32.
    33.       mov      AL,CH
    34.       mov      DX,PRINTERPORTBASEADDRESS
    35.       out        DX,AL
    36.       mov      AL,01h
    37.       mov      DX,PRINTERPORTBASEADDRESS+2
    38.       out        DX,AL    ; enable display
    39.       call       Delay
    40. ;
    41.       mov      AL,00h
    42.       mov      DX,PRINTERPORTBASEADDRESS+2
    43.       out        DX,AL
    44.       pop       AX    ; pop CL (minutes)
    45.       mov      DX,PRINTERPORTBASEADDRESS
    46.       out        DX,AL
    47.       mov      AL,02h
    48.       mov      DX,PRINTERPORTBASEADDRESS+2
    49.       out        DX,AL    ; enable display
    50.       call       Delay
    51. ;
    52.       mov      AL,00h
    53.       mov      DX,PRINTERPORTBASEADDRESS+2
    54.       out        DX,AL
    55.       pop       AX    ; pop DH (seconds)
    56.       mov    AL,AH
    57.       mov      DX,PRINTERPORTBASEADDRESS
    58.       out        DX,AL
    59.       mov      AL,08h
    60.       mov      DX,PRINTERPORTBASEADDRESS+2
    61.       out        DX,AL    ; enable display
    62.       call       Delay
    63. ;
    64.       mov      DX,PRINTERPORTBASEADDRESS+2
    65.       mov      AL,00h
    66.       out        DX,AL
    67.       ret
    68.
    69. DisplayTime ENDP
    70.
    71. Delay Proc
    72.       MOV CX, 00100h
    73. X:  PUSH CX
    74.       MOV CX, 0FFFFh
    75. Y:  LOOP Y
    76.       POP CX
    77.       LOOP X
    78.       RET
    79. Delay ENDP
    80. END
    and the circuit:
    http://postimage.org/image/2egfc6wsk/
  2. maonin
    Oct 15, 2011
    please help.
  3. nerdegutta
    Dec 15, 2009
    2,565
    806
    This is an international forum. Give it time.
    Besides, I think there is something with your circuit...
  4. maonin
    Oct 15, 2011
    please help...
    what is wrong with the circuit?
    is the code right?
  5. nerdegutta
    Dec 15, 2009
    2,565
    806
    I don't know much about ASM, so I cannot assist you there.
    About the circuit:
    I'm not sure, but wouldn't D1, D3, D5 show the same? The same with D2, D4 and D6.
    They are connected to the same 7447. I think you need at least one 7447-IC for each 7-segment. That means 6 IC-7447.
  6. t06afre
    May 11, 2009
    5,939
    1,222
    If I am correct the 7-segments are multiplexed. So only one group is active at any moment. If they are switched fast enough which may be around 30 Hz or faster. The human eye will se it as they are constant turned on. The circuit looks OK. From what I can see it pass the sanity test at least.
    Then things do not work it is time to start debugging. Since you are using TASM. I guess you also have the Turbo Debugger. Run td.exe, the Turbo Debugger. And step through your code.
  7. maonin
    Oct 15, 2011
    we got it!
    thankU.
    the circuit is just fine.
    something in the code that is not right.
    thankU. Godbless. :)
