Patch Cable help.
Discussion in 'The Projects Forum' started by vultac, Mar 2, 2009.
  1. vultac
    Thread Starter Active Member
    Mar 2, 2009
    142
    Hi there ive attached a picture for the pins which im supposed to design a cable for could someone tell me what type of cable is needed for these type of pins thx!
      File size:
      148.8 KB
      21
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That is a pin header. You need to determine the pin spacing and get an IDC type cable assembly to match. You do mean "obtain" rather than "design", don't you?
  3. vultac
    Mar 2, 2009
    142
    yah obtain...so how could i determine the spacing n stuff?
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Try using a dial or electronic caliper; if you don't have one, try a precision ruler.
    A very common spacing is 2.54mm (0.1") center to center.
    There's also 2mm, and a variety of others.
    It's easier to measure the spacing between 10 pins, and divide the result by 10.
  5. vultac
    Mar 2, 2009
    142
    hi, actually i need to connect these pins to the input and output of my daq and where in stores could i get these cables connecting them and what are they called? thx for the replies guys
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Once you have the pin to pin spacing determined, look for an IDC cable to fit. You might have better luck looking on the Digi-Key or Mouser site for the cables.
    It's possible a computer cable for a hard drive will fit.
  7. vultac
    Mar 2, 2009
    142
    thx buddy...how about my next attachment ... what are those type of pins called?
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Those are extremely fuzzy - they might be RCA jacks. That is the same as for audio connectors.
  9. vultac
    Mar 2, 2009
    142
    could it be anything else? that output port acts as an input into my DAQ(1 analogue input and 1 gorund)
  10. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The picture is too blurry to see details. Sure look like RCA, though. The connectors carry coaxial cables.
  11. vultac
    Mar 2, 2009
    142
    Hey, here's another picture! thanks!
  12. vultac
    Mar 2, 2009
    142
    btw mate, the previous pin header...what type of conneCtors shud i use? ic ant find any website that could guide me with this. thx
  13. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    With the center pin visible, they look like SMA. Get a drawing for an SMA PCB mount and see if the dimensions are correct.
    The cable that mates with the pin header may be an IDC type - those as for 2.54 mm pin to pin spacing.
    Everything depends on accurate measurements.
