Passive Ethernet Hub circuit question
Discussion in 'Computing and Networks' started by Tommy_cs, Jun 25, 2008.
  1. Tommy_cs
    Sep 25, 2005
    I have found 1 interesting circuit on the web.
    http://www.zen22142.zen.co.uk/Circuits/Interface/pethhub.htm
    Do anyone know the function of diodes in the circuit?
    I just don't understand why the diodes are arranged in pairs, in opposite direction. So what is the diference if all diodes is removed?
    Thanks!
    :confused::confused:
  2. Tommy_cs
    Sep 25, 2005
    Help!!! anyone have idea??:(
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    The only thing I can think of is a signal has to reach a certain threshold to be heard by the other computers. Personally I'm dubious, but if it works...
  4. studiot
    Nov 9, 2007
    5,005
    515
    This is an example of Diode - Resistor Logic circuitry.
    http://en.wikipedia.org/wiki/Diode_logic
    The diodes are connected 'back to back' to respond to positive and negative going signals.
    Early computer logic circuits were constructed like this, with boards containing thousands of diodes.
    The same idea was later incorporated into integrated circuits as multiple emitter transistor gates in TTL.
    Hope this helps
