Passing a signal through a shield
Discussion in 'General Electronics Chat' started by dannybeckett, Oct 7, 2014.
  1. dannybeckett
    Thread Starter Active Member
    Dec 9, 2009
    163
    Hi guys,
    Just a quick one - how do you properly pass a signal wire through a shield? I've heard of feed through capacitors but upon reading more, these don't seem like quite the right component.
    Cheers,
    Dan
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    several kinds of feedthrous are made, from just insulated streight through to built in inductance and shunt capacitance for blocking rf.
  3. #12
    Nov 30, 2010
    16,690
    7,330
    This is really old news, but in 1970, a feed thru capacitor meant a solid wire going through the metal case and it has capacitance to the case intentionally calibrated, usually in the neighborhood of 10 pf. What? They don't make those any more?
  4. crutschow
    Mar 14, 2008
    13,498
    3,374
    What is the nature of the signal?
  5. dannybeckett
    Dec 9, 2009
    163
    The signal is simply a 300kHz sine. I want to pass it through a faraday cage shield such that the shield and signal wire have no interaction with each other whatsoever
  6. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
