Pass Transistor
Discussion in 'Homework Help' started by sunshine27, Mar 14, 2011.
  1. sunshine27
    Feb 24, 2011
    7
    Calculate the output impedance of the emitter-follower circuit called the pass transistor: assume that beta=200
    **see attached diagram**
    I don't know how to do this, I thought that it would just be the 1k resistor, because that is the resistor that we are measuring vout across, but I don't think that is it.... any help would be great!!
  2. USMCJames
    Mar 14, 2011
    If memory serves correct, I believe the formula you are looking for is Zin = Beta * Emitter Resistor (200 * 1k)
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    The question actually relates to the output resistance rather than input resistance.
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    Rout is approximately Re|| (re+Rbase/β)
    re=26/Ie(mA)
    Assume a β of say 200.
    Rbase= 6k8||10k
    Re=1K
    Then you have it.
