Part selection for push pull follower help
Discussion in 'The Projects Forum' started by bskerr88, Oct 12, 2011.
Thread Status:
Not open for further replies.
  1. bskerr88
    Mar 2, 2011
    Hello all!
    First of all thanks for your help.. I've learned a ton just lurking around the forum and reading the online books.
    Anyways I've attached the LTSpice .ASC file I am working with.
    I am trying to create a push pull follower because a voltage transducer I'm using can't source enough current to a low impedance load. A little background.. this is a MV (~38kV) capacitive voltage divider, roughly a 10000:1 ratio of primary voltage to secondary voltage.
    If you guys see anything glaringly wrong with my schematic please let em know.. I really need help selecting parts though. I go on digikey and I don't even know where to start sorting. I have not purchased anything yet, and I am definitely willing to play around with different components, but want to waste too much money trying different ones.
    thanks!
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Ahhh, wait a minute - why on earth are you trying to use a capacitive voltage divider?
    You must use a transformer to isolate the circuit from high voltage. This forum does not support discussions of capacitive voltage dividers, as they cannot be made safe.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    I can't view this schematic. Many users can't either. Could you please repost it as a graphic file, .png preferred?
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    OK Bill, here is an edited version of our OP's schematic; I tend to remove a lot of white space from people's simulations, and eliminate components that aren't really necessary to make it easier to see what's going on.
    Next to symbol V1 is the statement: SINE(0 22000 60)
    which means a sine wave that has a 22kv peak (44kv peak-peak) value, 60Hz.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Visualize what would happen if C1 fails. It becomes a major safety hazard for anyone in the same room. We insist on transformers on this site for the same reasons. I strongly suggest transformer for this circuit instead of the dangerous capacitive voltage divider. If you want to pick up the discussion about where and how to get such a transformer you may start another thread.
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
Thread Status:
