Parital derivation
Discussion in 'Math' started by mo2015mo, May 11, 2013.
  1. mo2015mo
    May 9, 2013
    157
    Hi guys :) ,
    I have been having problems with the attached question, I have tried to solve it But don't get the correct answer
    i want to know HOW can derive the function under the root square
    plz help meee
  2. studiot
    Nov 9, 2007
    5,005
    515
    How come this isn't in homework?
    Have you heard of implicit differentiation?
    Square both sides, for example
    {y^2} = uv
    Differentiate with respect to u, holding v constant.
    \begin{array}{l}<br />
 2y\frac{{\partial y}}{{\partial u}} = \frac{{\partial (uv)}}{{\partial u}} = v \\ <br />
 \frac{{\partial y}}{{\partial u}} = \frac{v}{{2y}} = \frac{v}{{2\sqrt {uv} }} = \frac{{\sqrt v }}{{2\sqrt u }} \\ <br />
 \end{array}
    If you are not familiar with implicit differentiaion, you can do this one the ordinary way as follows
    y = \sqrt {uv}  = {u^{\frac{1}{2}}}{v^{\frac{1}{2}}}
 y = \sqrt {uv}  = {u^{\frac{1}{2}}}{v^{\frac{1}{2}}} \\ <br />
 \frac{{\partial y}}{{\partial u}} = \frac{1}{2}{u^{ - \frac{1}{2}}}{v^{\frac{1}{2}}} = \frac{{\sqrt v }}{{2\sqrt u }} \\ <br />
 \end{array}
    As before.
    In this instance implicit differentiation offers no real advantages, but sometimes it is the only way and often it is the easiest way with a square root involved.
    Does this help?
    mo2015mo likes this.
  3. mo2015mo
    May 9, 2013
    157
    yes yes i have heard of implicit differentiation ,But it did not come into My mind :(
    Studiot
    Thank you so much for all you’ve done to help me :)
  4. studiot
    Nov 9, 2007
    5,005
    515
    Presumably you can finish all the rest off now?
  5. mo2015mo
    May 9, 2013
    157
    yes, i have solved the rest and gotten the correct answer
    Thanks again for help me :) :)
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    Good. I would recommend doing them directly, as well, and verifying that you get the same answers.
