Parasitic capacitance of a bridge rectifier diode
Discussion in 'General Electronics Chat' started by uwed, Jun 19, 2015.
  1. uwed
    Mar 16, 2015
    64
    17
    I need to know a good estimate for the parasitic capacitance of a bridge rectifier diode (50/60Hz) roughly in the parameter range 1.2V and 10A. I can't find anything in datasheets. I would like to know if this capacitance is in the range of 10pF or 100pF or 1nF or even higher.
  2. #12
    Nov 30, 2010
    16,663
    7,307
    datasheet, page 1
    datasheet, page 2
    uwed likes this.
  3. uwed
    Mar 16, 2015
    64
    17
    Thank you, a good starting point! Do you think the capacity would increase in case such rectifier diode dies would be in a little power module (diode bridge)? Probably not ... ?
  4. #12
    Nov 30, 2010
    16,663
    7,307
    A dead diode that is shorted, therefore is not a capacitor, it's a conductor.
    A dead diode that is open is probably still a capacitor.
  5. uwed
    Mar 16, 2015
    64
    17
    Thank you for the datasheets! That answered my question.
  6. crutschow
    Mar 14, 2008
    13,472
    3,359
    But probably a much smaller capacitor since an open diode likely means a break in the internal connection so you would not see the normal junction capacitance.
    uwed and #12 like this.
  7. dl324
    Distinguished Member
    Mar 30, 2015
    3,375
    651
    Are you talking about reverse biased junction capacitance, or forward? When reverse biased, junction capacitance will decrease with increasing voltage. The opposite happens when forward biased.
    uwed likes this.
  8. uwed
    Mar 16, 2015
    64
    17
    It is about a simple model of common mode current paths in a converter. So I thought about a parasitic capacitor in parallel to an ideal diode for the diode bridge. But according to comments from crutschow and dl324 it wouldn't work like this? I know there are good spice models available for such a task but for this project I use a simulator that works with ideal diodes and switches.
