Parasitic capacitance across switch
Discussion in 'General Electronics Chat' started by anhnha, Dec 31, 2015.
  1. anhnha
    Thread Starter Active Member
    Apr 19, 2012
    776
    48
    Could anybody explain this more?
    Why there is a voltage spike during turn-off period?
    Also how it decrease the crossover loss?
  2. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I think when the switch is in off position suddenly there is increase in resistance than of conductor because the medium is air now.
    so, the molecule get energized and leave some spark especially in DC!
  3. Jony130
    Feb 17, 2009
    3,993
    1,116
    If you don't know the answer now. Do not worry, in chapter 5 you will find more about this crossover losses.
    As for the spike what about parasitic inductance?
  4. anhnha
    Apr 19, 2012
    776
    48
    Thanks but actually I need a more detailed answer.
    Thanks Jony. I am waiting for the chapter!
    For inductance it is easier to understand. Because VL = L di/dt, so when switch changes from OFF to ON (here di is large while dt is small) VL is large.
  5. crutschow
    Mar 14, 2008
    13,515
    3,386
    Any voltage spikes are generated by the stray circuit inductance. This inductance tries to keep the current flowing, generating a spike when this flow is interrupted by the switch.
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
