Paralleling remote control buttons for a toy car with 12F675 circuit.
Discussion in 'The Projects Forum' started by willums, Feb 21, 2015.
  1. willums
    Feb 21, 2015
    With pic power off, the RC buttons are seemingly connected to each other from inside the pic. Are the pins internally connected at power off and can I avoid this?
  2. #12
    Nov 30, 2010
    16,705
    7,358
    The input pins would be likely to have a diode each connected to the power pin as a safety for the inputs. Does this idea match what you're seeing?
    With no voltage on the power pin, the diodes will only cause 5 or 6 tenths of a volt difference.
  3. willums
    Feb 21, 2015
    Thanks AAC When one RC button is pressed (providing an earth) then other functions are initiated, which means a common earth is provided from the pic pins.
