If one takes a -- 100K ohm 10 turn Clarostat, and places a 1K resistor of equal wattage, in parallel to the untapped element, that reduces the 10 turn to a less-than-1K 10 turn ??? yes / no ???
I am aware that if you parallel two 100 ohm resistors, you get an equivalent of around 50 ohms, but this represents a dividend between equals...
How far can one push the uneven balance ... a 100 K and a 1K and still have a useable variable element ?? how does this affect the current of the load... Which takes more of a load, or does the Ohms Law dictate that the current splits evenly across both...
Maybe I should burn up a few packrat components, and answer the question that way.... If I go that route, I'll publish results...
