Hi All,
I have a project that is driven through the parallel port with software on XP to read/write directly to the parallel port. It would be nice if I could convert this to USB for greater flexibility so that I can make use of more modern laptops that tend not to come with parallel ports. Ideally I would like to keep things simple from a programming perspective, I don't want to get deeply involved in the in's and out's of programming for USB ports. I'm not shy of getting my hands dirty when it comes to programming, it's just the time factor. The ideal situation for me would be to get a program module that I can plug into my existing software which I can call with the parallel port instructions I normally use, for the program module to convert this to USB format, transmit this data through the USB port and into a device that will convert the USB data back into parallel port output. I imagined that there would be a common need for a solution like this but I'm surprised that I can't seem to find anything suitable. I have seen devices that convert USB to parallel for parallel printers, would these be a good starting point? Are there any off the shelf solutions out there? Any help much appreciated.
