parallel to serial conversion
Discussion in 'Wireless & RF Design' started by eeeplato, Feb 4, 2016.
  1. eeeplato
    Feb 4, 2016
    hello world...... i convert analog voice signal to digital signal(8 bits).... now i want to get converted parallel digital data as serial data via digital pin 1.... now what should i do? any suggestions for this purpose??? thanks.....
  2. ErnieM
    Apr 24, 2011
    7,443
    1,628
    Hi eeeplato, welcome to the forums.
    What is this "pin 1" you mention? Is the ADC part of some other controller like a micro processor?
  3. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    You need a UART IC, they can convert both ways.
    Max.
  4. crutschow
    Mar 14, 2008
    13,518
    3,386
    Just use an A/D converter with a serial output.
  5. fiberstorejames
    Aug 5, 2014
    18
    get a converter to tackle this issue..
  6. WBahn
    Mar 31, 2012
    18,093
    4,918
    You have not given anywhere near enough information to get meaningful responses. The people reading your post are having to guess at what you have and what you want and what your constraints are.
