I want to know how i can enable parallel port using C++ .
I mean what is the code i need to help me in programming ?
having done some VB6 code to do bit banging on a parallel port (unfortunately - i knew little else at the time- VB is annoying at times) i recall having to select and enable a port before use, i believe this grants access (through windows layers at least) to a program to transmit and receive signals on the port.I didn't know they had to be enabled. Aren't they available all the time?
by Jake Hertz
by Duane Benson
by Aaron Carman
by Jake Hertz
