Parallel port interfacing of a dc motor using adc0804
Discussion in 'The Projects Forum' started by masab_ahmad, Dec 20, 2010.
  1. masab_ahmad
    Dec 16, 2010
    i am using a dc motor as a generator which will provide input to the adc0804 which further will be connected to the parallel port to be read by the computer. So I wanted to ask by what procedure should i use the adc0804 like what should i do with the adc pins except the data output pins...I intend to use the following circuit(attached)..with LED's at the data output pins and a motor working as a generator at Vin(+).
