Hello! I'm planning to parallel two TPS27081A high-side PFET switches to increase current throughput and decrease overheating that I'm experiencing at higher loads with just one switch. Is it okay to share the 10k pull-up resistor R1 between the two switches (space is extremely limited and my resistor array is used up) and also share the single logic line used to control the original single switch? Any special things I need to consider when paralleling two of these switches for power control (one output). Thanks for any help as I'm quite new to this!
