OK, I think I've got a likely candidate. Although I don't know which side is the primary and which is the secondary. One side has large wire 1.25mm and the other has small wire .43mm The large wire wraps approx 110 times and the small wire wraps approx 2400 times. There is no other taps. The outsie dims are 75mm x 75mm x 90mmtall and weighs in at a hefty 10lbs.
Kind of chicken to apply a 110V to this puppy without knowing what the consequnces will be if I hook it up to the wrong side.
