parallel inductance capacitance
Discussion in 'Homework Help' started by regexp, Nov 20, 2010.
  1. regexp
    Nov 20, 2010
    24
    I need to find the resulting vector of a resistor in parallel with a capacitance in parallel with an inductance.
    The complex impedances are -J50 and J200. The value of the resistor is 100Ω
    So i have  \frac{1}{\frac{1}{100}+\frac{1}{-j50}+\frac{1}{j200}}
    In the key to my textbook this should equate to 55.47\angle -56.31.
    And i don't get that...
    if I add the two complex impedances i have 100 + J150.
    \frac{1}{1/100 +1/150} = 60 \angle 56.31
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    The text answer is correct - you need to re-check your method.
    The components are in parallel - not in series. Adding the two complex terms as you have done would be OK if they in series.
