Parallel IGBT with MOSFET
khalid4145
Joined Jul 22, 2008
16
Hi guys,,,
Would it be possible to parallel IGBT with MOSFET? I have an IGBTs in my design. i want to put MOSFET (electronic switch controlled by microcontroller) in parallel to the IGBT to generate a short circuit across the IGBT. Please see the attachment.
SgtWookie
Joined Jul 17, 2007
22,230
As long as the emitter of the IGBT is at the same potential as the Vss/ground of the microcontroller, sure.
If it isn't, you will very likely damage the uC and/or the MOSFET.
An IRLZ34 or IRLZ44 would be a likely MOSFET candidate.
khalid4145
Joined Jul 22, 2008
16
Actually the IGBT is driven from optocoupler driver circuit which isolate the PWM input of the microcontroller and the driver circuit of the IGBT. Thats means the IGBT and logic level MOSFET has different grounds. How can i solve the proplem??? I am using another circuit to measure or sense the voltage across the IGBT as shown in the following attachements. Please advice does the circuit make sense?
SgtWookie
Joined Jul 17, 2007
22,230
You're not showing enough of the circuit.
In the upper diagram, you show an 8A current coming towards the collector of the IGBT, and a wire dangling from the IGBT's emitter. You can't have current flow if there is no path to ground.
You do not show where the load is for the IGBT; I'm assuming it is about 3.75 Ohms in resistance?
It is preferable to post your schematic and waveforms as .png or .gif graphics rather than Word documents; they take up much less space on the Board and load much faster for those trying to help you.
