Parallel DC Circuits Worksheet Q1
Discussion in 'General Electronics Chat' started by Legion6789, Feb 13, 2014.
  1. Legion6789
    Feb 8, 2014
    7
    Question 1 of this worksheet: http://www.allaboutcircuits.com/worksheets/dc_p.html
    I got the answers right, but in the answer it states "You might want to mention that in electrical parlance, a "heavy" load is one that draws a large amount of current, and thus has a large resistance. This circuit, which shows how the lowest resistance in a parallel circuit consumes the most power, gives practical support to the term "heavy" used to describe loads."
    The first phrase says that a heavy load draws a large amount of current and thus has a large resistance. This seems backwards as large resistances lead to less current. This fact is reinforced in the question where the 1 ohm resistor has 3 times the current of the 3 ohm resistor going through it.
    The second phrase makes sense as it states that low resistances lead to greater power dissipation.
    So is the "heaviness" of a load determined by the resistance, the current or the power dissipation?
    Also, is the phrase "a 'heavy' load is one that draws a large amount of current, and thus has a large resistance" incorrect? Or am I misunderstanding something?
  2. Veracohr
    Jan 3, 2011
    559
    77
    'Heavy' is just a colloquialism, but it generally means a load that demands a lot of current from the source.
    You're correct, that sentence is inaccurate.
  3. Legion6789
    Feb 8, 2014
    7
    Thanks for the answer!
  4. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    But read careflully:
    A large amount of current implies a low, small resistance, so the above is wrong? ( I did not go back to the book to see if the quote was accurate.
